Show Entire Model not working - AC24 Migrated from 23.
Changing TO SHOW "ENTIRE MODEL" has no effect.......
Thomas Allan Palmer
Architect AIBC MRAIC
ArchiCAD 24 MacBook Pro
Mac OS Catalina 10.15.6
7 Replies 7
Are you saying that there is an entire brick skin missing or is it just the texture image on the surface?
Have you checked that no renovation filter or graphic override is in use?
Yes there is an entire brick face missing - not just a texture.
I've gone through the graphic overrides etc. but to no avail.
I'm thinking it might be some kind of view option based on the new structural analysis features in AC 24.......
Other files seem to behave...
Thomas Allan Palmer
I have not really played with that.
I would assume it would not affect anything unless you have been playing with it.
Could it just be a layer that is turned off?
tried turning all layers on. this is a composite wall issue
only core is showing
Thomas Allan Palmer
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi Thomas,
Thank you very much for your report and I am very sorry about the issue!
I tried to look for a similar report in our database, but it seems like we haven't got anything like this when migrating from AC23 to AC24.
Is it possible for you to share the files in Archicad 23 and 24 for further investigation? Please let me know if you need a secure place to upload the files?
Thank you very much, and I look forward to hearing from you!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Minh,
Where should I send it?
Thomas Allan Palmer
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi Thomas,
Thank you very much for your answer! I sent you a link in Private Message to collect the file. Please let me know when the file is ready.
Thank you very much!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
