Arcadia
Showing door without wall?
Is there any way I can show a door (in this case a roller door) in 3D and sections etc without showing the wall? Ie: I have modelled an industrial steel framed shed and have modelled all the steel purlins/girts/framing. I have put in walls and roof panels so I can use them to apply the wall cladding and roof cladding using Cadimage accessories. In 3d I can then turn the walls/roof layers off so I have an accurate looking 3D which shows all the external cladding and internal framing but now I just have holes in the walls not doors. Help!
V12-V27, PC: Ryzen 9 3950X, 64g RAM, RTX5000, Win 11
5 Replies 5
You will need to add a wall in a layer that does not get turned off.
Make this wall the same size or smaller than the door you place in it.
That way the hole the door cuts will completely hide the wall.
Arcadia
Thanks I never thought of that. I actually reduced the wall thickness down to 2mm so that I could leave its layer switched on but it doesn't interfere with the framing and that works okay but your idea is better.
Steve Jepson
you could also give the wall .001 height
Mark Wallace
This is a similar method I use but in reverse, for Demo layouts where things being removed can be shown and then made to 'disappear' in the new design.
Mark
ArchiCAD 12 2675 USA Full + 11, 10, 9 & 7, Mac G5 Dual 2.3 Ghz, 1.5 Gb, OSX.4.11, HP T1100, Epson R1800
Mark R. Wallace AIA
Mark Wallace Architect
Collegeville, PA
Mark R. Wallace AIA
MacBook 2.53 Ghz, Intel Core i5, 8 Gb,
Mac OSX (Sierra 10.12.6,
ArchiCAD 22 USA Full, +21, & 20.
All good answers, here's mine:
This method uses a wall located far away from the door that is placed "in" it. Doors and windows can be placed "in" a wall that is far away from the door itself - either vertically, or horizontally. In first case your wall might be in a specially created subbasement, the door sill might be at 50 feet and therefore show up on story 3 or 4. In the other case, place a wall somewhere off your rendered view space, place your door in it and then slide door back into your desired position.
The net effect is that you will not have a hard to detect wall anywhere in your active workspace that might accidentally get swept up in some other operation. I use the subbasement routine myself, easier to keep track of the relationships when needed, especially with the trace function.
Mark
