Showing on Core on Composite
When defining a composite wall, I set the core to the main structure, such as concrete or stud.
Is there a way to turn off the composite wall portion and only show the core. In some instances I would prefer only to see the core of the composite and not the entire wall, such as providing the information to a structural or civil engineer.
Thanks, Grant
Jacek
I don't think that there is a way, at least not a straghtforward one.
The only thing that you can do is Display; Solid Fills, Empty fills or play around with Bitmaps/Vectors.
You can also define the line weights to show up more in plan/section in Option, Composites.
I think that is it, unless someone knows more about this....?
Chime in.
jacek lisiewicz
arkhos-tekton, architects
carmichael, ca
Mac OS X 10.15.5
IMac Retina 5K, Intel Core I7
32 GIG Memory, AMD Radeon R9
ArchiCAD 24
aahatimo
NOELDESIGNS wrote:
When defining a composite wall, I set the core to the main structure, such as concrete or stud. Is there a way to turn off the composite wall portion and only show the core.
grant, sounds like a great wish list item. i miss that option from our 'old' cad program.
tim hanagan
aaha! design studio durango, co
27" retina 5k iMac 4ghz i7 os 10.13.6 m395x 4 mb, 32gb ram, 512 gb ssd ac 22 current
15" retina mbp 2.6ghz 1mb 16gb ac 22 current[/size]
aahatimo
http://www.graphisoft.com/community/archicad-talk/viewtopic.php?t=1876&sid=e39a139f48b83fdc036ab3489...
thanks, grant!
tim hanagan
