2010-12-16 12:28 AM - last edited on 2023-05-24 07:59 PM by Rubia Torres
2010-12-16 02:35 AM
2010-12-16 02:54 AM
Matthew wrote:Elevate.
In 3D there is a pet palette option to drag vertically and assuming you have the tracker enabled you can easily type in the offset.
I forget the command name to do it in plan but the (US) default shortcut is command/control+9 which brings up the dialog into which you type the offset.
2011-01-02 03:00 PM
2011-01-02 05:25 PM
2011-01-03 12:00 AM
