2024 Technology Preview Program
Simple morph question: Extrude a 2d morph into a 3d morph
svpribyl
Is it possible to extrude a 2d morph that is created in the plan view into a 3d morph in a 3d view?
Thanks.
Steve
Mac OSX 10.8
Steve Pribyl
MAC OS Sonoma 14.5
ArchiCAD 27
11 REPLIES 11
Eduardo Rolon
Yes. But you have to switch to the 3D View first. 2D Morphs (lines and planes) show up in the 3D Window.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
svpribyl
How is this accomplished? I can see the 2d morph in the 3d window. I can push and pull the face of a 3d morph in a 3d window, but I can't push or pull the face of the 2d morph in order to make it 3d: the entire morph moves. I tried all the modifier key combinations like command-shift, control-shift, etc.
Thanks
Steve Pribyl
MAC OS Sonoma 14.5
ArchiCAD 27
Eduardo Rolon
You need to use the "sub-select" arrow to select the face then click on it so you get the flyout.
The shortcut for the sub-select arrow is control+command+shift on Mac.
Or you can click twice on the surface to get the flyout.
AC27 US/INT -> AC08
another Moderator
Eduardo Rolon
You need to get this to show.
AC27 US/INT -> AC08
another Moderator
svpribyl
I have tried it with the hollow cursor but I can't get that pet palette to show up. The only pop-out that I can get is shown here.
Steve Pribyl
MAC OS Sonoma 14.5
ArchiCAD 27
Eduardo Rolon
You need to click on the surface, not on a node or segment.
1. Press Esc to cancel any command running
2. Click on the surface once to select the Morph
3. Click on the surface again to get the Pet Palette.
On another note, if you imported your W/E from another version of AC you might need to reset it to see the new commands but this is a longshot.
http://helpcenter.graphisoft.com/guides/archicad-17-int-reference-guide/virtual-building/constructio...
AC27 US/INT -> AC08
another Moderator
svpribyl
That's exactly what I'm doing. With the hollow cursor I click on the face to select the face of the morph. The face is highlighted. I click again on the face and the pop-up that I see is the one that I posted above.
I just tried this with a 3d morph. One click selects the face of the 3d morph and the second click shows the same pop-up palette as above. The difference is that I can push and pull the face, even though the "wrong" palette is showing. I still don't see the pet palette that you posted above.
Do you think this is a bug or some hardware incompatibility?
Steve
Steve Pribyl
MAC OS Sonoma 14.5
ArchiCAD 27
Eduardo Rolon
OS 10.6 is not recommended for 17 though you can use it.
I would try doing a New and Reset to see if it shows the Palette. If it does then I would start checking my Work Environment to see if there is something missing there.
AC27 US/INT -> AC08
another Moderator
svpribyl
I'm using ArchiCAD 16.
Steve Pribyl
MAC OS Sonoma 14.5
ArchiCAD 27
