ananas
Simplified side view of profiles
Hi!
I have a detailled profile, that I would like to keep detailed in 3D and sections.
I would like to simplify it though in the Elevation view and I wonder if that is possible?
Here I am attaching a printscreen of the side view of the profile. I would like to reduce the amount of lines on the side view.
Does anyone know how to achieve that?
Operating system used: Windows 11 Pro 23H2
runxel
It's not possible afaik. Sadly.
I was hoping the Design Options could be expanded so something like this would be possible. The technology is obviously there.
A Design Option for the element would be possible, but then again, you would need to do everything twice, and if something changes.... etc.... Only okay for Presentation plans maybe, otherwise too much of a hassle.
But I agree, we urgently need some kind of LoD for profiles!
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
ananas
Thank you for explaining.
Design options seem like a good solution!, but is only possible in Archicad 27. The project I work on is in older Archicad 25.
I think i will draw another simplified profile and put on another layer or I ll use renovation filters.
