Siteplan
Does anyone know if it is possible to make a plan/story that show all the other stories f.ex siteplan with everything on it. That is without using camera unless the camera can be set as ortographic. (?)
10 REPLIES 10
I not sure I understand what you want to do, but...
If you want to show all the stories side by side, you could hotlink them all into a single story of a separate PLN.
If you want to show them in a stacked relationship, you could increase (temporarily) all the floor to floor heights and make an isometric 3D view.
I guess I could maybe get what I want in an axonometry view. But what I'm really looking for is to have a window just like the other stories only I want to show all stories in one, like a rotated elevation maybe. f.ex. I see the roof and I see the balconies from the story under and even the stairs on the ground floor .....get it?
Djordje
... and the purpose is ... ?
If you want to lay out the plans etc, PlotMaker is the real place.
If you want to see all the stories "through" each one, that is not so easy in ArchiCAD, but is easy again in PlotMaker - just make all of them transparent, including the fills backgrounds.
Caould you post a screenshot of what you want to achieve?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Arild,
Are you looking for something like the attached? I just inserted additional stories at about 10m each to explode the building vertically.
The camera can be set directly above and then the distance to object increased digitally to a very large number. I did it once ages ago.
But maybe you would be happier to set the roofs to be 'visible on all stories'.
aahatimo
nice work matthew!
tim hanagan
aaha! design studio durango, co
27" retina 5k iMac 4ghz i7 os 10.13.6 m395x 4 mb, 32gb ram, 512 gb ssd ac 22 current
15" retina mbp 2.6ghz 1mb 16gb ac 22 current[/size]
Tom Krowka
Matt:
How did you insert the stories. That is a great isometric. Did you start a new plan, then insert each floor as a module some distance apart?
Or, did you separate each floor (temporarily) like you mentioned in an earlier post.
Thanks.
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
No modules. (Though that would work too.) I just modified the file I was working on for the demonstration. I have used the technique for real before. It's really nice for lease management and construction phasing.
Just go to the Options > Stories > Story Settings (command/control-7 by default) and insert the stories.
I would recommend to delete them after you are done, as it is easier just to reinsert them the next time than to navigate through them in the meantime.
Djordje
... or change the distance to the next storey to twice or thrice the current value.
Djordje
HP Omen
