Sketchup import not showing up in Archicad 26
onestoreyllc
I've imported a Sketchup file to Archicad but nothing shows up in the 3d window.  In the 2d window I can grab the import as an object but there is no visual for the object, just empty.  All of my renovation filters are set to 'show', all layers are visible, no overrides.
I've also tried converting the SKP file to 3ds and DXF.  The 3ds file does the same as the SKP and the DXF file takes a few hours to import and then is impossible to rotate, section or any other option for viewing.
Can someone help?
Meredith
AC26 USA - Lenovo P17 - Intel(R) Core(TM) i9-10885H CPU @ 2.4GHz - 32.0GB - Windows 11 Pro
Is it possible that the imported model is located very far from the (0,0,0) origin?  That can cause all kinds of issues if so...
One of the forum moderators
AC 27 USA and earlier   •   macOS Ventura 13.6.9, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
From everything I see, it's located adjacent to the origin.
Meredith
Patrick M
skp comes in as an object. make sure your filter/cut elements in 3d is not hiding the object tool. otherwise, the only ways to show/hide are layer or renovation filter (aside from bMat issues which do not apply to objects).
