Our customers might be experiencing service disruptions due to a global outage at Microsoft Azure. Our team is actively monitoring the situation and working to minimize the impact. Thank you for your patience and understanding.
Skin Priorities for Composite Walls
Hello all.
I searched and could not find an answer to this.
We are having a problem with our skin priorities. We go through and set them up correctly and everything looks fine, but when we quit the file and then open it again, the skin priorities for the composite walls revert to some sort of default (where all skins have a priority 2, for example) and then we have to set them up all over again. Obviously, this cannot be correct. Anyone else run across this?
Sean
ArchiCAD 11
Mac OSX
4 REPLIES 4
David Larrew
Which AC build are you running? Be sure you are on the latest build (1210).
David Larrew, AIA, GDLA, GSRC
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
Erika Epstein
Sean, another possibility is that after you go through and set the changes you might be forgetting to hit the UPDATE button.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Thanks for the replies.
We ran a couple of tests today and think that we have figured this out. After looking into it, it seemed to only be happening on teamworked projects. So we figured out that only the team leader (signed in with exclusive access) can modify the skin priorities for the project.
This, of course, makes perfect sense and all is right in the world.
David Larrew
You are correct. Once shared, certain project properties/options can only be changed/saved by the "Team Leader". And sometimes the TL would also need "Exclusive Access".
AC 5.1-25 USA
