Slab Display on Multiple Floors
I have a slab drawn on let say floor 1. I set it to display on "one story up" this make the slab display on floros one and 2. However on floor 2 the outline of the slab is dashed and not solid. I can not find any settings that would make the slab display solid on both floors. Maybe i'm missing something simple. Any ideas?
try setting your construction elements>above home story to solid lines. however, now all elements set to read from this construction method will be solid.
if slabs had floor plan display options (correct me if I am wrong) this wouldn't be a problem.
In AC 10 go to Options->Project preferences->Construction elements
and change the line type.
Peter Devlin
