Sloped Curtain Wall Common Frame
Does anybody know how to create common frames for two slanted CW (as seen in the attachment) or any workaround for a cleaner model where the boundary frames don't overlap with the other CW. I've already tried changing the boundary frames to invisible but the transom also overlaps with the other CW. I'm using AC19 if that helps. Thanks in advance!
0 REPLIES 0
