‎2003-11-17 02:08 PM
‎2003-11-17 02:44 PM
BryanRichards wrote:You'll have to use a roof to create the slope : either use "cut by roof" method or "Solid element operation" method
Is it possible to slope the top of a wall, so for example in section, the top right corner will be lower then the top left.
‎2003-11-17 04:21 PM
BryanRichards wrote:As Geoffroy said, use the roof to cut the excess off, or now SEO - be sure to place the operators on dedicated layers so it can be turned off, and make it Wireframe in order to see properly what are you doing.
Is it possible to slope the top of a wall, so for example in section, the top right corner will be lower then the top left. (not a leaning wall)
PS Ive now got my archicad8 as so many of you people were emphasising an upgrade was due from 7. Ive got the solids to import from ADT, will it be any different now i have got archicad 8?No such luck, I'm afraid ...
‎2003-11-17 05:17 PM
‎2003-11-17 05:24 PM
BryanRichards wrote:Select the wall(s) that you want to cut, and the roof plane. Right click, look for Trim to roof.
Ive constructed 4 simple walls creating an enclosure. Inside of the 4 walls i have a sloped roof that potentially cuts right into the outer perimeter of the wall all around. What tool do i use to get rid of the excess wall above the roof point? where is this cut to roof option?
Next problem, once i can do that im only one step closer to where i want to be. I cannot create my roof in Archicad, even from the solid obects from the library. If i was to make my roof as a solid from ATD then import, which is possible, can i cut the walls to the imported library roof?You should, using the SEO; what is the roof like?
‎2003-11-17 05:39 PM
‎2003-11-17 05:40 PM
‎2003-11-17 05:47 PM
‎2003-11-17 06:42 PM
‎2003-11-17 07:19 PM
BryanRichards wrote:Reply to this mpost. In the bottom, there is an attachment field, Browse, Attach ...
how do y ou import a picture into the forum reply text box? The picture is saved in m documents
