Sloping Profiler
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2006-01-31 03:25 AM
Thanks, as usual.
Scott
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2006-01-31 10:28 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2006-01-31 11:44 AM
Scott wrote:Use ArchiForma add-on or 3D Profiler from CadImageTools instead AC std profiler in such cases.
I seem to have forgotten how to make a sloping profile. Can someone please advise me before I kill myself.
Scott
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2006-01-31 03:57 PM
Scott
Scott:
If you don't already have 3D Profiler.... check with your Archicad reseller. I "think" it was packaged with an Archicad subscription (update to 10), along with "Virtual Tutor 9".
Marc
Red Canoe Architecture, P. A.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2006-01-31 06:40 PM
If you don't already have 3D Profiler.... check with your Archicad reseller. I "think" it was packaged with an Archicad subscription (update to 10), along with "Virtual Tutor 9".Marc/Zohrab,
You are correct. 3D Profiler from CadImage will make what we need (Carrere, your's must be from CadImage). The Profiler tool within AC9 only defines horizontal objects. Further as mentioned, CadImage's 3D Profiler now comes with the subscription for AC10, clearly the way to go.
Thanks so much for your time.
Scott
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2006-02-01 04:23 AM
Thank you,
Scott
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2006-02-01 04:34 AM
Check out this thread.
Peter Devlin
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2006-02-01 05:21 AM
You might want to consider whether this detail will actually work out in the field. I'm not sure that a carpenter could realistically miter this corner and get it to work properly without a slight return, a corner block, or something to aid in the transition. You might be better off with a different detail here.
AC26 (since AC6.0), Win10
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2006-02-01 05:41 AM
If the cross section is held constantExcellent descriptive geometry explanation that I agree with. Prior to making my post we did try breaking up the corner into segments that partially worked, but not very well. I was hoping that, as partially noted in the manual, one could slope one segment of the whole to the roof solving this problem. If you can't, then close enough will have to do.
then the miter can't be plumb and you have to make a transition houlder. This is very similar to the classical "raking moldings" geometry.
Further I agree with Richard's comments, but I don't think that 3D Profiler can do that either.
Thank you again for your thoughts.
Scott
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2006-02-01 05:54 AM
As Richard points out there are geometry problems with what
you are trying to do.
In the thread I referenced in my last post and the thread
referenced in that thread the issues involving Profiler and
more generally eave rake transitions are discussed.
I made some eave to rake transitions using some molding
profile objects to test those issues.
Please see attached image.
#2 was made by scaling the eave moulding vertically
so that it's plumb cut length is equal to the the eave
molding's plumb cut length.
I extended this object and then tried to subtract with
down ward extrusion the eave molding from the rake
molding using SEO. I might try again too see if I can
get #2 to work because I think this was done in classical
detailing by carving the scaled rake profile to meet the eave profile.
Peter Devlin
