Slowness between sections and floor plan
rjwilden
Archcad V10 has recently developed a problem with a long pause after being in a section window and going back to the floor plan. 6-8 seconds before I can pick or move an object on the floor plan. The problem also exist to a lesser degree going into a manually linked section. Again a 5-6 second pause.
I've done the normal things to clean up the computer, but to no avail .
I have tried removing all library objects, but that dosent fix it
I note that in V9 There is no problem, the transition is instant. Zero waiting. Any ideas how I might rectify this
Thanks Richard.
Richard Wilden Design. Ltd
Dunedin, New Zealand.
Imac 27" i9 3.6GHz; 32GB Ram Mac OS 11.3
Archicad V23:V24
Richard
Which update of AC10 are you on? I've notice similar behaviour (still on 1010), most annoyingly in detail windows, but recently going back to plan after being in a section too. Not sure when that started, but it was recently, not related to any update that I have performed.
Richard,
I have also noticed this with about the same time delays. At first I didn't know what was happening so I was clicking in the plan window to do something and nothing was happening and then it would release and I would be into a drawing command. Quite annoying as it did not used to be this way. I am on the latest update.
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 29-Latest USA
2024 M4 Max MacBook Pro-macOS 15.5 (128GB (16 Core CPU + 40 Core GPU)
rjwilden
I am on the latest release 1183 NZE full.
And now that you mention it the slowness would have started around the time I downloaded the latest release.
The long pause in the detail window has been with V11 the whole time. What I do to get round this is select the detail in the tool selection and change the boundary box to the one with the X in it. This in turn puts a dashed circle around the detail label in navigator instead of a dashed square. Shouldnt have to do this though.
I have found V10 to be a lot slower to navigate around than was V9
Archicad V23:V24
