We value your input!
Snap to both geometry and construction grid?
Mike96
Is it possible to enable simultaneous snapping to regular geometry and construction grid or snap grid?
ArchiCAD 25
Windows 10
4 REPLIES 4
Eduardo Rolon
If you are referring to snapping to geometry that does not align to the construction grid the answer is no.
In the sample below if grid snap is on you will not be able to snap to any object.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Yes, this is just what I meant, and I expected such an answer but wanted to make sure I'm not missing something.
It's a bit of a shame though, it would be useful.
But thanks anyway! I may post it as a wish one day.
ArchiCAD 25
Windows 10
Fortunately you can set up a keyboard shortcut to toggle between snap modes, which I am guessing you are aware of.
Just noting it so everyone is aware.
SHIFT+S I believe is the default shortcut, you could even change it to just S (or something else).
Myself, I always have the co-ordinates palette active for this and other options, so it is just a quick button swap.
Mike96
Thanks Barry but that wouldn't help me anyway, cause I actually needed to snap to intersections between the grid and geometry. I guess I'd have to draw my own grid with actual lines but I eventually managed to go around the problem 🙂
ArchiCAD 25
Windows 10
