Smitstituur
Snap tool problems
I have a problem with selection/snap tool while drawing, mainly in plan. If I select a wall, wall, etc. and want to model or edit it, the mouse does not move. At least, the mouse does move, but not visually and you only see that when you make a random sound somewhere. This can be solved by hovering over the dialogue box. This makes my work much more inefficient.
Does anyone know how I can get this back to the old settings? I installed the snap tools exactly the same as my colleague, but everything works as it was.
2 Replies 2
What version of Archicad?
Is it up to date with the latest update/hotfix?
What operating system?
What are your machine specifications?
Guru
Following from Barry, these details should be added to your forum signature, see links in mine, as some issues are specific to a version or OS, etc.
