2011-08-20 05:57 PM - last edited on 2023-05-25 04:51 PM by Rubia Torres
2011-10-05 09:45 PM
2011-10-05 09:54 PM
If you change the parameters via Edit Stair, then you'll need to select another stair from the browser area, and then re-select the stair you just edited -- this assigns the stair the default settings (as you just changed via Edit Stair).
2011-10-05 10:18 PM
2011-10-05 10:57 PM
simonblencowe wrote:OK button doesn't make any "symbol settings" changes anymore. (geometry settings can be changed, it's ok with that...) "Edit Stair" has changed in 15, this is a bug and sorry, Laura doesn't want to understand what we say about this issue. I wrote to Graphisoft about this and still waiting a response.
I agree, on AC14 I didn't, but AC15 for me no longer works that way unless i do a save as to make an edit. Any edit will not take place if I just select ok.
2011-10-05 11:20 PM
