Hello does anyone know how to change a source view after something has already been drawn.
Problem: the issue is that when i draw my framing plans i want to see the floor walls below, example: first floor framing plans below you would see your basement walls. However, i am seeing the floor above. the source view says that but i cant change it anyone out there know how to fix this
This is not possible AFAIK. You'll need to recreate the view, which is pretty easy - just double click on the existing view, then drag the other viewpoint over in your Organizer. If it's already placed as a drawing on a layout, just use the drawing manager to relink it to the new view.
