‎2006-06-06 10:43 PM
‎2006-06-07 12:21 AM
How does one enable Special Menu in AC10?The same way as it was in AC9. Karl O. gave a tutorial on it here:
‎2006-06-07 07:31 AM
‎2006-06-07 07:51 AM
Karls method doesn't work on a Mac.Care to explain why? Seems to be quite straightforward to me.
‎2006-06-07 07:55 AM
‎2006-06-07 08:11 AM
Karl's method is for either platform after the special menu is enabled in the Registry or by editing the plistYep - it was all included in the link. Ben explained it. He basically said:
.... modify the file:Seems straightforward, but maybe Cameron has found a problem?
~/Library/Preferences/com.graphisoft.archicad9.plist
... open the file .... and find the lines of text that tell it to turn the special menu on. alter the 'no' to a 'yes' (or perhaps a '0' to a '1').
.... use the developer tool 'Plist Editor' which is installed as a part of the developer tools package. everybody has a developer tools installer file installed as a part of the default mac OSX install. you can find it in ./Applications/Installers/ ...
... once you've installed the developer tools, the Plist Editor can be found in ./Developer/Applications/ ...
‎2006-06-07 03:22 PM
Link wrote:the problem is that there is no special menu defined in the work environments of the mac version of archicad 10! you have to actually define the menu yourself once you've enabled it in the plist file . . .
‎2006-06-07 11:31 PM
the problem is that there is no special menu defined in the work environments of the mac version of archicad 10! you have to actually define the menu yourself once you've enabled it in the plist file . .Unless I am missing something, what you describe above is exactly what happens on a PC too. We have to manually rebuild our Special menu, which is why we have to follow the instructions so closely.
‎2006-06-08 03:28 PM
Link wrote:yeah - it simply doesn't exist. as far as i remember it didn't even show in 'All menus in alphabetical order' either . . . i had to build it as a brand new menu myself.
Is the more to it than that?![]()
