We value your input!
Special Menu
I have on many attempts followed the "Special Menu" procedure, I have version 13.
1) Open Windows Registry from Start Menu
2) HKEY_CURRENT_USER\Software\Graphisoft\ArchiCAD\ArchiCAD 13.0.0 INT R1
Set value of DWORD Special Menu to 1
Opened Work Environment- no special menu
Opened ArchiCAD and created a new menu called 'special menu'
nothing.
Much appreciated
Cocolebon.
Katalin Takacs
Graphisoft Alumni
Graphisoft Alumni
There are some steps that should be checked again:
- Did you select the correct ArchiCAD in Regedit? Please check HKEY_CURRENT_USER\Software\Graphisoft\ArchiCAD-64 folder, too, if you have one.
- Restart ArchiCAD. Work Environment/Menus » If you have created a new menu, called Special Menu, I can recommend you to list the application commands by theme. The last folder is '60 Special' where you can find the content of Special menu.
http://archicadwiki.com/SpecialMenu
Katalin Takacs
Katalin Takacs
You are indeed a rare find,
Thankyou very much for your reply, the file has been located.
Kind Regards
Coco
Katalin Takacs
Graphisoft Alumni
Graphisoft Alumni
You're welcome, Coco!
Katalin Takacs
