Special Menu?
I was just browsing Archiguide and read an article that mentioned using the section tool in 3d. I t also mentioned a "special menu" that was accessed by holding down the cntrl and alt keys while starting AC ! Can anyone explain this?
8 Replies 8
Link
Well we could tell you, but first you have to become a member of our 'special club'.
Just kidding - I believe it is a menu that the programmers use to test features. Some existing options in AC have come from this menu. Align 3D texture is one of them, for example.
Play around with it - some of the 3D features are pretty cool.
Link.
Djordje
Naaah ... we can always kill him 😉
Go to http://www.graphisoft.com/community/archicad-talk/viewtopic.php?p=2411#2411
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
I can't get to the special menu with the alt and cntrl keys. All I get is a windows menu with settings for the shortcut?
Dwight
Hold those keys while starting ArchiCAD not while it runs.
Dwight Atkinson
Actually, if I'm to understand what you're saying (and from personal experience) you have to hold down those keys while ArchiCAD is starting up (i.e.: right after you doubleclick on the icon or so). Otherwise windows missunderstands what you're trying to do (alt-click? or ctrl-alt-click?).
I cannot get to the special menu Help Please! What and exactly when do you press?
Try:
http://archicad-talk.graphisoft.com/viewtopic.php?p=2411#2411
I feel very dense. I had it the whole time. I thought the menu would jump out at me like a window when it worked. Instead it silently went to the menu bar whare it belonged. Duh!
