Spell Cchecker Crashing
Using Spell Checker consistently causes my ArchiCAD to crash.
Anyone else have this problem?
I seems to happen with the @ symbol.
5 REPLIES 5
rjwilden
Have had this problem for years, get round it by selecting the text you want to spell check. Dont do a global check.
Richard.
Richard Wilden Design. Ltd
Dunedin, New Zealand.
Imac 27" i9 3.6GHz; 32GB Ram Mac OS 11.3
Archicad V23:V24
tried that and it still crashes. It searches for a while and then quits when I try to ignore or replace something.
Steve,
I just tried the global spell check and specific "box" spell check with the @
both next to other type and isolated in string and did not have problem.
But project I test on did not have tons of type.(??)
Larry
I think it is something in the drawing. ? On some files it seems to work fine.
Paul King
Mentor
Yes - I have this problem too. I reported to Graphisoft but no solution forthcoming, though it apparently "only" affects PC versions.
Checking only one story or view at a time , then saving after each view checked (because checking next view could crash your project & loose your previous corrections) can help - but a painful process.
PAUL KING | https://www.prime.net.nz
ArchiCAD 8-28 | Twinmotion 2024
Windoze 11 PC | Intel Core i9 10900K | Nvidia Gforce RTX 3080 | 32 Gb DDR3 | 2x4K monitor extended desktop
