Spiral Parking Ramp
I need some hint how to construct Spiral Multy Story Parking Ramp with ArchiCAd 9...
I would Appreciate any suggestion ....
What Library part should I use ....
THX in advance
I. Benutic
5 REPLIES 5
What about using the stair tool and create a ramp.
You can also use the predefined shapes
Can You be more specific ... as I understand, when I use stair tool I have to specify number of raisers ... I need spiral car parking ramp with flat surface ....
Correct me if I'm wrong...
I. Benutic
Duple click the stair tool and in the panel "preview and Positioning" click on the single arrow next to the name of the stair and choose "Create new stair"
In the new window "Stair Type Selection" if you look on the top you can see 2 buttons,one for a usual stair and one for ramp.
But i don't know if you can use all predefined types for a ramp ,additional to this there are some add-ons such as ArchiStair or StairBuilder(i am not sure about the second one)
There is also a library item named "Curved Ramp " in the structural elements folder, try this too.
Dwight
Curved Ramp.gsm
Object in Library:
03 Concrete>Concrete Structures.
Dwight Atkinson
That's it ..... Thanks a lot to both of You
.... really
I. Benutic
