isakeveborn
Split curtain wall to to levels
I have a curtain wall that goes from storey 01 to 04. I want to split this curtain wall so that it's 4 curtain walls, one per storey.
How do I do this? I have tried to create a section and then use the split tool but the curtain wall does not split at all.
1 Solution
Charlie64
Oh, I don't think you can do that.
But maybe you can make one and copy it to the other floors? If the differences are small you just manualy correct few floors, instead of making each floor manualy.
Good luck!
Go to post
3 Replies 3
Charlie64
May I ask how did you make the curtain wall? Because I tried to replicate what you said you did so first I drew columns and slabs in floor plan, and then I drew curtain wall in floor plan as well. I did not change anything (height of the wall and stories), and got the curtain wall only for the floor which I picked. Then I copied it to other floors and got curtain wall for each story.
Hope that helps.
isakeveborn
I did not create the model, I am just doing some changes and my client wants the curtain wall split per floor.
Since I have about 15 of these I am trying to find out if it's easy to just split them instead of making new ones.
Charlie64
Good luck!
