ā2006-08-30 01:51 PM
ā2006-08-30 02:48 PM
ā2006-08-30 03:47 PM
ā2006-08-30 05:25 PM
ā2006-09-01 09:00 AM
gbley wrote:No.
I can't make a case for or against splitting projects although it seems to me that we had split projects with Plotmaker. If you split a project, does it negate the advantage of layout integration??
ā2006-09-01 01:20 PM
ā2006-09-01 02:03 PM
TomWaltz wrote:So this basically means I shall recommend my abusers to split the project if they suffer from excessive twiddling of thumbs...
One major benefit of splitting the files is that you can have one performing updates while you work in the other. If you keep them together in one file, you are twiddling your thumbs while the views on layouts update.
To me, the benefits of Plotmaker integration are autosave, teamwork, and being able to place objects on layouts.
