‎2004-12-29
11:27 PM
‎2023-05-26
09:02 AM
Rubia Torres
‎2004-12-31 01:38 PM
‎2004-12-31 02:16 PM
StuartJames wrote:Hey... why didn't I think of that!
... Using a 'hidden line 'plan' 3d view' just means less thought - as long as you physically have the correct relation between the objects in 3d they show up correctly 'in plan'.
- Use of this (.2dl) is pretty much the same as the patch tool.
‎2005-01-04 01:31 AM
StuartJames wrote:Is there a way to hack some level of parametric linking out of this technique?
One thing we've done (on occasion) in the past to 'get round' the ANNOYING limitations of AC stacking (as Geoff has discovered) is save a 'plan 3d view' as 2d elements.
This is a messy workaround, but it works.
HTH - Stuart
‎2005-01-04 05:11 PM
‎2012-08-15 09:54 AM
‎2012-08-15 03:21 PM
kimfromzim wrote:Kim, great that you bring this up, can you make a new wish?
Really, manually re-ordering the stack level, every time a slab in an overlapping-slabs-situation is edited, is a ridiculous 'arrangement' (pun intended).
All the above workarounds are for an object. Simply dealing with a proper BIM and having things display according to the reality - a plan shows things at a higher elevation being displayed in front of things of a lower elevation..
‎2012-08-15 03:52 PM
‎2012-08-16 10:38 AM
