Stacking or complex wall
Is it best to stack differant type walls or use the complex wall tool to get differant wall materials on the elevation of the walls? I am wondering what the differance will be in the data base and the flexibility of the wall after it has been made/built?
17 Replies 17
drawing@jbdg wrote:
OK i am using the complex profile for a wall. Everything seems to work until i went to place the origin to place my wall reference line. It does not go where i put it on the profile of the wall. In other words the origin placement and the reference line do not match. This drives me crazy!!! Is this normal??
Make sure that your ref line offset value in the wall settings dialog (or info box) is set to zero (0). And, verify that you placed your profile relative to the true origin, not a temporarily relocated user origin.
Karl
Link
Karl wrote:
troakie wrote:
I have spent a very frustrating few days creating a model where the windows are recessed into a wall and 'span' three materials but the reveal adopts only one of them - if anybody can give me a workaround for this I would be eternally grateful!
I can't. Complex profiles provide a HUGE amount of productivity to ArchiCAD users. But, they have the INFURIATING and stupid limitation that the wall (e.g.) ends are assigned a single material (for renders; fill/hatch for line drawings), regardless of the number of skins/etc. It drives me insane...
For doors and windows we can apply the Wall Opening Material to be either the 'Same as Wall Edge' or the 'Same as Wall Side' via the options under the Model panel of the tool's settings. Maybe additional materials could be offered via GDL coding?
The only workaround I can see is to use Solid Element Operations and make sure the target inherits the attributes of the operator. Not the most ideal solution, as you'd probably need multiple elements with multiple materials to use as your operators, but it would get the job done.
Keep in mind that the operator will need to be on a different layer than the target, with a different intersection ID for this to work.
The reference line of the wall is directly related to the complex profile's local origin. So go back into your Profile's Settings and move all the elements back so they sit on the origin. Don't forget to turn on all your Design Layers, so that you move your drafting, stretch and opening lines too.
The rule is that the fill's shape and orientation will reflect how the resulting profile will look when you cut a section through it and look in the direction from the start of the profile to the end, in the direction you modeled it.
Link.
Dwight
Kermul wrote:
INFURIATING and stupid limitation that the wall (e.g.) ends are assigned a single material. It drives me insane...
"I hate that Halley's comet.
It makes me sick, i want to vomit."
And just to save everyone's time suspecting that a thin wall can be simply inserted into the sides of the window opening, say....
if you do it the obvious way, by putting a thin wall directly and exactly inside the opening, some clever guy in the basement in Budapest made it so the wallhole disappears the tiny wall, but if the thin wall insert is just a smidgeon [sorry to not know the metric equivalent for our European members - a smidgeometre - i suspect] off, it works.
In the attached examples, the left window edge is a thin wall sitting almost inside the window opening. The right window edge is a thin wall wrapped back to disguise the edge of the thin wall.
Dwight Atkinson
Dwight
The way to make a wall END represent its material is to wrap the end back. Make a corner exactly the depth of the wall.
Dwight Atkinson
Dwight
This wrap doesn't show oddly in the plan representation.
Dwight Atkinson
Dwight
And for all sides to work you need to take the reference line back again along the back.
A WOrkaround where you genuinely "work around!!!!"
Dwight Atkinson
With all respect, Dwight and Link, you're not "getting it" IMHO...so no general 'workaround' awards from my POV. Yes, not too bad for striped walls, which was the original question.
Sure, stripey extrusions can wrap. But, layered veneers will not display their layers when looked at from the wall end, or the sides of a cut hole. If you have something as simple as a two veneer wall with brick applied to masonry block - the wall end will be one solid material. You cannot get it to show brick and concrete - as either texture or fill.
Solid Element tricks do not work either without painful modeling, since you cannot model a 4' wall as 4', but have to extend it a longer amount so that you can then embed your subtraction elements to use Link's trick. Viable for the two veneer rectangular example I just gave. Not at all viable in a general, complex case...which different materials vertically, horizontally, and with the profile dimensions perhaps changing on the way towards final documents.
Graphisoft themselves give an example of this in the wiki article here:
http://www.archicadwiki.com/TechNotes/Composite_Walls_with_Varying_Skin_Heights?highlight=%28TechNot...
(link may be too long for ac-talk - may have to cut/paste)
The three OpenGL screenshots at the bottom of that page show a white brick pattern covering the entire wall end. We see some brick (incorrectly assigned) on the plywood surface because the air gap with a complex wall is a real air space, allowing us to see through to the interior surface.
Karl
Complex profiles still need a fair amount of work. While I appreciate these concerns for high quality wrapping and stuff (and would heartily applaud improvements in this area). How about a simple material override? I find it extremely frustrating to need a multiple trim profiles just to have different paint colors, or creating a special beam profile in florescent chartreuse to call attention to a questionable structural detail.
