Stair Design
Ok so I'm designing a stair case, I've drawn the "slabs" which are tilted at about 12 degrees w.r.t. to the projects normal and now I want to connect the slabs with stairs. I know how to create custom stairs, but is there an option to snap the stair to the edge of the slab and align it to the slab's rotation of 12 degrees.
Thanks In Advance
David Maudlin
Ayman:
To place the stair at angle, use the second Geometry Method (Rotated) in the Info Box. When placing the stair, you can use the Relative Construction Methods (in the Control Box palette) to align the stair perpendicular to the edge of the slab. Or you could just place the stair and use the Relative Construction Methods to rotate the stair afterwards.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
