SOLVED!
Stair Maker - L-run with landing -> single tread/rise at top
Johan Stinckens
I am struggling to get the desired stair for a project I am currently working on. I need an L-run stair with landing and just one single tread at the top.
When using Stairmaker I can only limit the risers at the top to "2". But I only need/want just one riser after the stair makes a 90° turn on the landing.
Johan Stinckens
BIM Modeller at Atrium Architecten
Archicad user since April 2014 (v17 - v27) - CC iRT i9-12900 - 64 GB / Nvidia Geforce RTX 3080 - Windows 10 Pro 64
Other than that it's hiking, camping, climbing.
1 ACCEPTED SOLUTION
Solution
David Maudlin
Johan:
I was able to make this stair using the Create Stair Using Selection (Fill & Lines) method, in the Help files see: Elements of the Virtual Building > Custom Stairs with StairMaker > Custom Stair Based on Manually Drawn Elements.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
3 REPLIES 3
Johan Stinckens
Attached a view of the area in which I've currently place a straight stair and modelled the landing and extra stair using slabs/beams.
However, I would like to have a consistent respresentation of the stairs throughout the whole project. The other stairs correctly display riser numbers. Since this stair is only partially moddelled using the stairmaker, both the walking line and riser number are displayed incorrectly.
Thus my question "how can I restrict the upper riser count to just one"?
Johan Stinckens
Solution
David Maudlin
Johan:
David
I wish stair maker would allow customised landing placement.
