Rail under leaves
Hi All,
Does anyone know how to change a the 'rail line' beneath a sliding door to show as a different line weight from the frame?
They both appear to be controlled by the 'frame contour pen' which is fairly stupid.
The frame is cut in section so needs to be a thick line, the rail is on the floor so needs to be thin.
Any thoughts on a solution (bar draw a line in 2D which seems to be the work around for most things on archicad).
Regards,
Tom
0 Replies 0
