Stair Rails?
How can we put the railing only the inside of the stairs. There are only 3 ways to place them. ( both inside and outside, outside, one side)
Should i use ArchiStair to make a perfect stair?
4 REPLIES 4
To make the "perfect stair" don't use any add-on or automation.
Just model it.
It is faster in the end and you get exactly what you want instead of having to settle for "close enough" and editing the end results in 2d.
Thank you Steave,
i think they put an option for to replace the railing only the inner side of the stair.
Modeling can be the best way for this... sometimes i miss the Autocad
When you are creating the stair and are in the stair rail window you can click on the side of the diagram you wish to have the rail. Or use the both option and set the side you do not want to see to none.
Thank you very much plandesman!
i love archicad
