Stair numbering hidden by a balustrade
As shown on this image, our associative balustrade on the stair covers up the tread numbering in plan. Might be missing something obvious here as I can't find it elsewhere on this forum. Is there a way to offset the numbering in MVO or the stair settings?
Thanks for any help,
2 Replies 2
The MVO will only have an option to show or hide the numbering.
Delve into the stair settings and you should see a section for the numbering.
In there you should find an offset parameter.
It maybe a 'Relative position on tread' expressed as a %.
You can also go into 'EDIT' mode for the stair.
Select 'Symbol' in the dialogue box and so long as you are not using the 'Built-in' numbering you should see a moveable hotspot for the numbering when you select it.
The built-in numbering does not seem to have a moveable hotspot
This is the field Barry is referring to.
