Stair problem again!! And again!!
Heeeeelp!!!
I cannot build this stair, can anyone tell me why ???
Thank you!
8 Replies 8
You don't give enough info to be sure. It would help to post the settings dialog with the parameters shown.
One possibility is that there is not enough setback/return at the landings (or winders as the case may be). The stair tool can't align the end of one winder tread directly over the end of the one below.
It doesnt show any other window than that.
But I think you are right there is not enough space.
Ill try again
i get your stair . . . but there is a little hidden trick
anyway archicad stairs are terrible !
Heyyy!!!
How did you do that?
Although, I think that the lengths in your stair are bigger.
I post another image with dimensions, I think that the problem is where the treads turn, or not ?
And in inches
i was not able to create your stair i was limited to structure of stairs...check pic down
i was not able to create your stair in archicad stairs . . .
I think that you will have to model them manualy.
i could only create them with these kind of structure . . .
Yes!!!
Thank you very much!!
