Learn more
KeesW
Stair risers
I am drawing an existing garden stair with 200 - 220 high risers. I've changed the default settings for stairs to allow risers upto 220. The Archicad 26 stair tool only appears to permit risers upto 191mm - regardless of the default settings. The Cadimage polystair seems to allow it but has other problems which make it unusable. How can I alter the Archicad stair tool to allow non-standard risers above the 191 mm legal height?.
Cornelis (Kees) Wegman
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
1 Solution
KeesW
Thank you. I figured that out myself - eventually! it was the '2R + G' that controlled these items and by changing this I was able to get the stairs to work.
Go to post
3 Replies 3
hevi
Ace
Have you tuned off any of the rules which might limit the riser height?
DGSketcher
Legend
I came across this the other day. The stair limit is applied as "less than" rather than "less than or equal to". Increase the riser limit and it should work. I think I had to change the limit, close the object and then reopen it for the new limits to update all the options.
KeesW
