2018-09-19 11:50 PM - last edited on 2023-05-25 04:41 PM by Rubia Torres
2018-09-20 12:12 AM
2018-09-20 04:13 AM
2018-09-23 10:29 PM
2018-09-23 11:16 PM
2018-09-24 08:42 AM
2018-09-24 10:38 AM
PrendosJoe wrote:Same problem here in the UK with the push for compact stairs. You did mention favourites, which suggests a degree of repetition. If the stair tool isn't working for you then provided the stairs remain constant, then modelling them and converting them to a component may be the better option and quicker. They might also look more like what the joiner needs to produce.
We also very often have scenarios where the first & last tread are the first & last winder as per the attached which the stair tool seems to think is impossible... are you able to shed any light on getting this result?
2018-09-25 09:17 AM
PrendosJoe wrote:Hello PrendosJoe,
Hi Barry,
Thank you for your reply. I do have the settings as per your post however it still refuses to work in many instances. We also very often have scenarios where the first & last tread are the first & last winder as per the attached which the stair tool seems to think is impossible... are you able to shed any light on getting this result?
Many thanks!
2018-09-25 10:24 AM
2018-10-17 05:17 AM
