2018-09-19 11:50 PM - last edited on 2023-05-25 04:41 PM by Rubia Torres
2019-07-31 06:10 PM
2019-08-01 04:01 AM
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
2019-08-02 02:45 PM
Geof wrote:Hi,
Hi Daniel, thanks for offering to look into quirky stair situations. Here's what I typically have to model.
(Or let me know where I should sent this outside of this thread)
2021-12-26 12:40 PM - edited 2021-12-26 12:49 PM
Two years and versions later, and quite a few stairs managed, yesterday I hit a new issue. The Custom profile stringers do not work properly at the internal corners. Only by tweaking the connections - IF they want to work - an approximate result can be achieved.
Treads extend to the sides to the outer boundary of the stringers, instead of ending at the inside of the stringers.
Handrail that is magic wanded on the stair ref line in 3D is losing its associativity if moved to the correct height, because otherwise it clashes with the stringer profile. I should also mention the top rail connections at turns of the staircase.
While the staircase tool is powerful, it shows the problem with any automation or AI - it is as good as the programmer's understanding of the subject. Steel staircases are common. It is not only wood and concrete.
Check... https://cdcon-my.sharepoint.com/:u:/g/personal/djordje_archcorner_net/EWJJcWpW3C5InzJtRsLNoUwBcr4gPM...
2022-01-07 02:57 PM
Thank you very much for the report and I am so sorry for the experience!
I downloaded the BIMx file, and indeed I could see the mentioned problem. To help with the investigation, I'm wondering if you could share the original PLN file with us, so that we can investigate how it reaches this state? If you need a secure place to upload the file, feel free to let us know!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2022-01-08 06:11 AM
Thanks for the reply 🙂
Please let me have the upload link.
2022-01-10 12:40 PM
Hi Djordje,
I have sent the link in a Private Message. Hope you have received it by now.
Could you please let me know when the file is uploaded?
Thank you very much!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
2022-01-10 12:45 PM
Thanks, Minh
Uploading now.
2022-07-06 06:18 AM
Daniel Alexander Kovacs,
I have attempted to do that stair in 22 and can't get it to work. I also need a single line of stairs with the 3 winders at the bottom only and it never seems to work. Do you have a video tutorial where I can get the basics?
2023-06-05 05:56 AM
I know this is an old thread but now in AC 26 is seems much worse. I am so frustrated at the complexity of this stupid tool that I'm considering quitting Archicad all together. Just getting walk lines and UP / DN labels correct is a joke. There is so much control over every aspect of a stair that it is OUT of Control!
