SOLVED!
Stair - up/down text
Johann_P
How would I show the stair up/down text in views of different scales?
In views of 1:100 and 1:50 it's necessary to show the text, but in scales 1:200 the text is too big and I'd like to not show it.
But if I remove the text in the stair settings, it's removed in all the views.
ArchiCAD24 - since Nov 2020
Revit - 2005 to 2020
Windows 10 Pro
2 screens: nvidia quadro RTX 4000
1 ACCEPTED SOLUTION
Solution
David Maudlin
Johann.P:
Rather than controlling the display of the text in the Stair settings, you can use MVO. Under Stair Settings > Floor Plan Display > check by Model View Options, then edit your MVOs to turn on or off the Up/Down Text (under Stair Options) for different Views.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
2 REPLIES 2
Solution
David Maudlin
Johann.P:
David
Johann_P
Awesome. Thanks.
Windows 10 Pro
