Staircase - Starting from a corner
Hi, I'm having a problem building a staircase.
On the left I built a 3D staircase very simply using individual floor slabs with 2D annotation over the top. Now I'm learning about how to use the proper 3D stairs but so far I can't figure out a way to get the 3D to match the 2D. I need my staircase to have the angled corner style, but I also need the staircase to START on the angled corner like it's shown on the left. Anytime I try to manipulate the 3D stair it snaps to a straight run. Is there a tickbox somewhere to specify 'start on the corner' or a work around that anybody knows of?
Also, how do I control the style of the stair run arrow, I want to take off the little circle at the end.
I'm running ArchiCAD 22.
Thanks!
Hannah
22 Replies 22
David Maudlin
LaszloNagy wrote:
So, all I could do is to take an old trick and just cover that last Tread on the Floor Plan with a Fill that has the same background as the Floor Plan Viewpoint.
Laszlo:
Very well illustrated solution. Rather than a fill to hide the last tread, my standard pen set has a series of white lines that are a bit thicker than the standard pens. So I can simply draw a white line or polyline over any element that I want to hide. I have found this quicker than using fills.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David, good idea.
Jp1138
Nice, thank you very much! This kind of examples opens your mind to the possibilities of the software!
ARCHICAD 29 SPA (as long as the server works)
Windows 10
