Our customers might be experiencing service disruptions due to a global outage at Microsoft Azure. Our team is actively monitoring the situation and working to minimize the impact. Thank you for your patience and understanding.
Stairs: 'Create Independent Segments and Nodes' grayed out
Why is it I don't get 'Create Independent Segments…' in the pop-up menu, and it is grayed out in the Design>Modify Railing menu.
2 REPLIES 2
Podolsky
Ace
I've found in help centre about this command:
https://helpcenter.graphisoft.com/user-guide/134845/
But cannot activate it. It doesn't work in any circumstances!
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Dear All,
Thank you very much for your question!
This option appears, if Railing's Segment is divided into multiple segments.
A Segment is the part of the Railing between two Nodes. So If you are placing your Railing associative by clicking on the starting and endpoint of the stair, the entire Railing - no matter how many 'change of directions' are in the railing - will be considered as one Segment. In this case, this command can be used: applying the command means that at every 'turns' a Node will be added to the Baseline and you will have more than one Segment.
I hope this answers the question! Please let me know if there is anything unclear!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
