2005-05-13 09:54 PM - last edited a week ago by Molinda Prey
2005-05-14 03:36 PM
jcude wrote:Jeremy:
i have a set of stairs that go up over a closet and i need to hide the stairs under the closet so that that section of the stairs does not show up in the plot of the floor plan. is this possible?
2005-05-15 03:01 AM
2005-05-16 04:39 PM
Aussie wrote:I am not sure how this process is carried out. Can you give more info?
Cant you use storey sensitive to show break lines. These can be adjusted by editing the stair.
2005-05-17 12:54 AM
2005-05-21 12:27 PM
Aussie wrote:You may need to change the 'symbol type' to 'bottom only' if that is available in your actual stair object.
select the stairs- - open settings and the first parameter is called storey sensitive. Select that and the stairs will only go up to the break lines.
if you want to edit the break lines you have to select the stair and go to file>GDL objects>open object and the break lines can be grabbed inthe corners and moved.
