Story Above, Below, Home story
I have found out how to show the story below on most elements in archi-cad as well as specifying a line type. My problem now is that I want to show my slab w/ a cover fill to represent gravel topping. The issue is then when I go one floor down the cover fill shows up. I know i could draw the hatch w/ a fill but now if I have to change the slab size I need to adjust the fill accordingly. Not cool.
Any Solution would be helpful.
Thank you
Saul
2 REPLIES 2
__archiben
make it custom: see attached . . . the fills and outlines can be controlled separately.
~/archiben
b e n f r o s t
Thank you Archiben
