Story Setting
Hey guys,
How can I change the default story setting from 3100 to any height i like ?
5 REPLIES 5
Just modify the values to anything you like and save is as a Template.
Then, when starting a new project, use that Template.
Or, you may modify the default ARCHICAD Template as well (but in any case, I would have a backup copy of it if I modified it).
OMG the template solution worked, thank you. anyway how to change default ARCHICAD Template?
Or or i could just enter any height i want in ground floor and click on insert above ground floor.
James B
In AC20, you can also multi-select Stories and edit all Height to Next in one go.
James Badcock
WOW that's an amazing improvement.... they should have thought of this since the beginning.
