Story Setting
Hey guys,
How can I change the default story setting from 3100 to any height i like ?
5 REPLIES 5
Just modify the values to anything you like and save is as a Template.
Then, when starting a new project, use that Template.
Or, you may modify the default ARCHICAD Template as well (but in any case, I would have a backup copy of it if I modified it).
OMG the template solution worked, thank you. anyway how to change default ARCHICAD Template?
Or or i could just enter any height i want in ground floor and click on insert above ground floor.
James B
In AC20, you can also multi-select Stories and edit all Height to Next in one go.
James Badcock
Graphisoft Senior Product Manager
WOW that's an amazing improvement.... they should have thought of this since the beginning.
