2008-02-07 11:49 PM
2008-02-08 01:37 AM
2008-02-08 05:08 PM
2008-02-08 06:10 PM
2008-02-10 07:29 PM
HAL9000 wrote:If I were you, I would learn how not to use the fills ... one more thing to think about, that you don't really need.
I am creating elevations by using the section tool and then covering up the not needed parts with a solid white fill. The issues is when i go to print the sheet parts of lines show up around where the drawing frame would be. As if a little part of a line is right on the edge of the drawing frame. Does anyone have a solution to this problem. Thanks
