‎2012-03-08
04:08 PM
- last edited on
‎2023-05-24
12:58 PM
by
Rubia Torres
‎2012-03-09 03:08 AM
‎2012-03-09 03:10 AM
‎2012-03-09 03:13 AM
‎2012-03-09 08:27 AM
Barry wrote:Thanks, but that not helped.
If you use the Tracker then make sure it is set to "Relative Coordinates".
‎2012-03-09 08:35 AM
Rammstein wrote:It will always say "Relative Coordinates in Tracker" in the pull out menu but make sure the little icon next to this is active.
Yes, I'm using Tracker, and Relative Coordinates are always turned on.
‎2012-03-09 08:56 AM
‎2012-03-09 09:58 AM
Barry wrote:It stays at the beginning.
Does your user origin move to the strtching end of the wall when you hold SHIFT or does it just stay at the beginning?
Barry wrote:No. I will try.
Do you have the latest hotfix installed - build 3602?
‎2012-03-09 01:11 PM
Barry wrote:This solves the problem, thanks!
