‎2007-08-06
08:03 PM
‎2023-05-23
05:06 PM
Rubia Torres
‎2007-08-15 11:55 AM
Craig wrote:At the moment, I don't. I am considering ArchiCAD as the vehicle for my next project. At present it appears - despite the enormously useful contributions of Messrs. Waltz, Worden & Djordje - that certain essential aspects of it cannot be delivered with ArchiCAD.
This guy obviously has nothing better to do with his time than to moan and post reply after reply about how he can't get his columns to work.
‎2007-08-15 12:07 PM
~/archiben wrote:Well, without paying the King's Ransom, I can't save anything. I can indeed follow your thinking - makes perfect sense to me - but would need to know how the IF-class is created in the process.
ok. i see what you're saying. that is kind of true, but only takes a minute to fix:
‎2007-08-15 06:30 PM
‎2007-08-15 07:54 PM
Dennis wrote:I think so. Then, when nothing worked, I rang M.A.D. and they obviously are from Barcelona - "we know noothing". (I'm of course referring to Fawlty Towers, not actual Barcelona.)
According to this page, here is a fully functional trial program. Have you tried downloading from here?
‎2007-08-15 11:32 PM
‎2007-08-16 02:24 AM
Petri wrote:you're not creating the class - you're simply assigning that object to a specific building element subtype. it is these subtypes that are used by the IFC translation engine when exporting: an element in the Model Element>Building Elements>Column subtype - whether from the basic toolset or object-by-subtype - automatically gets exported to the equivalent IF class.
‎2007-08-16 02:33 AM
‎2007-08-16 11:34 AM
‎2007-08-16 12:04 PM
~/archiben wrote:Of course. I know that. FBOW, IFC is a prescribed system, so at theoretical level, it is not truly object-oriented. In an orthodox & ideal system, the user should be able to define new subclasses that would inherit properties from above. The other user might (and should!) only see what I choose her/him to see, ie. the common level at which our software can operate.
‎2007-08-16 02:49 PM
Rob wrote:Sounds sensible to me. (Assuming I get your drift.)
In other words, resolving all joints and mitering manually as oppose to a bit less detailed virtual building showing on GA plans and solving odds and sods in 2D detail.
