‎2004-10-23 03:23 AM
‎2004-10-24 07:10 PM
Ignacio wrote:Does that mean you might be in the area for ACUWest next year? (Of course, I realize that the schedule is not set yet. I assume it would be in the March/April time frame.)
It's the San Francisco Burbinger is thinking of. Luck and temperance.
‎2004-10-24 09:23 PM
‎2004-11-04 02:51 PM
Aaron wrote:That Add-On is comparing the outline of the shadowed area during the day at a given elevation to a curve that is specified by the authorities. It is using an external (non-graphisoft) engine.
Some time ago I was shown an Add-On (in the very early days of Add-Ons) that performed shadow studies in ArchiCAD and prepared data to submit data to the (Tokyo?) building authority. Apparently their requirements were quite complex.
‎2004-11-07 10:50 PM
"Ignacio" wrote:
I am needing to produce a sun study showing the net new shadow thrown on a park by a new building. If anybody knows any procedure better than what I figured and describe below, in any software, please let me know.
I did one once by making the new building transparent red, the existing buildings opaque. The extra shadow showed up reddish. Does this help?
‎2004-11-08 04:33 AM
HANIEL wrote:That would save a step or two, which multiplied by a zillion shots would be absolutely wonderful (the spreadsheet still needs to show the areas for the total shadows before and after, but with that method the graphic could be produced in a single step, as opposed to overlaying shots from two sun studies which was what I was thinking of).Ignacio wrote:
‎2004-11-08 04:39 AM
Burginger wrote:This is *the required procedure* in SF for any building throwing shadow on a park, and I am using a previous presentation by others as a model. The outside consultant has always done it in ArchiCAD, and it takes his staff like 6+ man-weeks! (he admits they are not super expert AC users, and I would guess/hope we might be able to cut some 5 to 5.5 weeks from the critical path thing).
Thinking seriously. Make an appointment with the planning board and /or request a copy of a previous project that they have accepted. This is an unusual requirement, otherwise you are quessing what is actually expected. Besides that, do you want the possible liability of the study? Outside consultants perhaps do this several times a year. Thinking outside the box.
‎2004-11-08 05:39 AM
‎2004-11-08 10:28 AM
Ignacio wrote:It was from archicad, but I suspect using bitmaps. Maybe vector, with transparency in shadows turned on would work Give it a try.HANIEL wrote:Ignacio wrote:...
So that was straight from ArchiCAD? I do need the output to be vectorial for the calculations. (If it was not ArchiCAD then, maybe with AC 9 and the new render engine it can now be --I am getting 9 in a week or two.)
‎2004-11-20 04:50 AM
‎2004-12-08 01:48 AM
