12 hours ago
How come some surfaces have no outline like this:
And others do? Like this...
How would I change this setting so the render surface has a solid outline because when I have a floor with a render structure applied, it doesn't show the outline.
Thanks
11 hours ago
That is a good question.
It is probably the solution to your other post ... https://community.graphisoft.com/t5/Visualization/Wall-surfaces/m-p/713591#M26954
The only thing is I do not know the answer.
All of my building materials have a solid perimeter to the surface fill and I can not see a way to turn it off.
If you open the render surface settings, what do you see there?
The surface should have a cover fill.
Does that have a perimeter?
This is what mine look s like.
