Surveyor's ordinances vs AC
How do you guys key in Surveyors’ ordinances? Well you know they take their bearings due north and zero deg. in AC is by default horizontal. The way I do it is to draw the lengths vertically and then rotate the line by its corresponding bearing. This I find rather laborious and presume there must be some shorter way….probably revolving around the skewed grid and grid switch buttons?! all I want is to punch in the length and angle and get it right in one fell sweep.
Any ideas someone?
10 Replies 10
Djordje
Rip wrote:
OK, but how do you draw a line at, say, 30˚ from the previuos line?
In general:
1. Start the line at the beginning of the first one
2. With the cursor on the existing line (Mercedes) type R and input lenght needed, then type A30+ and press enter.
What you get is a line of wanted lenght at an angle 30 degrees more than the first one.
HTH?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
