T Shaped Stairs
GeorgieB82
Hi all,
This is probably really simple but how do I create a T shaped staircase in AC22? I.e you go up a single run to a landing and then it splits to either side up to the final height.
Many Thanks
AC25 UK Solo
Windows 10 Pro, Intel Core i7-4790, 16GB RAM, NVIDIA Quadro K600
Eduardo Rolon
This link still applies
https://archicad-talk.graphisoft.com/viewtopic.php?f=20&t=52128&hilit=T+SHAPED+STAIRS
With the new Stair tool you will need to either create 2 stairs, one L and the short segment or create 3, one to landing, slab for a landing and then the other 2 runs
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
GeorgieB82
Blimey, thank you! I had totally forgotten that post 2 years ago!
AC25 UK Solo
